[SOLVED] Suggestion to add a dimension label colour attribute
petevick
Post by petevick » Tue May 19, 2020 9:19 pm
I would like to make a suggestion for a future update of Qcad, to add a dimension label colour attribute to Drawing and Application preferences in Dimension Settings, also an additional field to be added for this attribute in the Property Editor. I find that having a different label colour is easier to read the dimension value when checking drawings on the screen. It could also make drawings printed in colour easier to read.
I have used both AutoCad and DraftSight extensively in the past, and more recently LibreCad, all these applications have the ability to set the dimension label colour separately to that of the dimension lines colour.
Pete Vickerstaff
Linux Mint 19.3 Cinnamon, Qcad Pro 3.24.3
Re: Suggestion to add a dimension label colour attribute
Post by andrew » Sat May 23, 2020 9:34 pm
This has been implemented and will be included in the next snapshot release and possibly in the next stable release of QCAD Professional.
petevick
Post by petevick » Sat May 23, 2020 9:41 pm
Blimey, that's excellent e_surprised
Pete Vickerstaff
petevick
Post by petevick » Sun May 24, 2020 10:11 am
would this feature be in snapshot 3.24.3.6 or the next release :?:
Pete Vickerstaff
Post by andrew » Fri May 29, 2020 9:49 am
It's included in snapshot 3.24.3.7.
petevick
Post by petevick » Fri May 29, 2020 9:51 am
Thanks once again Andrew
Pete Vickerstaff
