- 2021-10-14_06-33.png (61.45 KiB) Viewed 4241 times
Text tool with dark theme and 4k monitor - leap of faith
Please see attached screenshot. With a dark theme (and a 4k monitor) the text tool is unreadable. The only real way to use it on significant portions of text is to copy/paste into it from a text editor.
- ryancousins
Re: Text tool with dark theme and 4k monitor - leap of faith
What version of QCAD are you running?
Please indicate also your operating system and the theme you are using.
