Show only the drawing command
Posted: Mon Oct 03, 2022 7:41 am
by ouilogique
It would be great to have a command that allows you to see only the drawing, that is, a command that hides all the panes and toolbars. This would be very useful for those who work on a laptop with a small screen.
See also:
https://www.qcad.org/rsforum/viewtopic.php?f=32&t=9575
Re: Show only the drawing command
Posted: Mon Oct 03, 2022 9:02 am
by CVH
The best place to make this request is here as a feature request:
It wouldn't be that hard to hide all toolbars and other widgets with a script.
The point is to remember what was visible and what wasn't in case you want to return. :Wink:
However, I have a problem with that.
What about the Status Bar, Options Toolbar and Command Line?
I think those are things you need even if you know all the shortcuts by heart.
Why not configure your setup as you want it with a maximized drawing area?
Most Widgets can then float when you activated them (G..).
