autocad 2018 errors using commandline conversion?
mikinturin
Post by mikinturin » Fri Mar 16, 2018 7:43 pm
Hi, we got errors converting autocad 2018 dwg's to any format (see below)
on ubuntu linux, qcad trial 3.19.2
(we wanted to buy, but have to be sure the software can convert our files using command line tools..)
QCAD version 3.19.2
Debug: RDwgPlugin::init: trial
Debug: RDxfPlugin::init
Debug: RPolygonPlugin::init: trial
Debug: RProScriptsPlugin::init: trial
Debug:
You are using a trial version of QCAD Professional.
Debug: If you would like to use this software productively,
Debug: please purchase the full version for a small license fee from our
Debug: Online Shop at:
Debug: http://www.ribbonsoft.com/shop
Debug: Thank you for trying this add-on!
Debug: Your script will start in 15 seconds...
Debug: RTriangulationPlugin::init: trial
Debug: calling odInitialize
Warning: RDwgImporter::importFile: reading: OdError:
Debug: "RDwgServices::printErrorStackTrace: Invalid file version"
Warning: RDwgImporter::importFile: trying to recover...
Warning: RDwgImporter::importFile: recovering: OdError:
Warning: "Import for file /FOLDERXXX/FILEXXX.dwg failed"
Cannot import file: /FOLDERXXX/FILEXXX.dwg
Re: autocad 2018 errors using commandline conversion?
Post by andrew » Fri Mar 16, 2018 10:02 pm
There are two different sets of packages for Linux:
- the Qt 5 based packages for all modern Linux distributions (qcad-3.19.2-trial-linux-x86_32.run / qcad-3.19.2-trial-linux-x86_64.run)
- the Qt 4 based legacy packages for older Linux distributions (qcad-3.19.2-trial-linux-qt4-x86_32.run, qcad-3.19.2-trial-linux-qt4-x86_64.run)
The Qt 5 based packages are recommended for most modern Linux distributions and support DXF/DWG <= 2018 (DXF/DWG R32).
The Qt 4 based packages are recommended only for older Linux distributions if the Qt 5 based version does not work due to incompatible gcc libraries. These packages only support DXF/DWG <= 2013 (DXF/DWG R27).
