[solved] How to restrict length of lines when drawing one
atossa
Post by atossa » Tue Jun 08, 2021 12:29 pm
If I click on https://qcad.org/doc/qcad/latest/refere ... ngleLength , I can restrict angle, it works well but whatever I enter in the length box doesn't seem to affect the line I'm drawing. I can still draw line with any length....
PoP OS 20.10, Qcad 3.26.2
As you can see in the screenshot. I try to draw a line of 0.3 length but I can get a 97.2 length line... It doesn't limit it to 0.3 as expected.
resutl : length line = 97.2
Capture d’écran du 2021-06-08 13-36-02.png (25.21 KiB) Viewed 442 times
drawing of line, desired to be of length 0.3
Capture d’écran du 2021-06-08 13-35-23.png (57.03 KiB) Viewed 442 times
Re: How to restrict length of lines when drawing one
Post by andrew » Tue Jun 08, 2021 12:51 pm
It limits to multiples of 0.3. In your screenshot that step is so small that you won't be able to see it. If you zoom in you will.
atossa
Post by atossa » Tue Jun 08, 2021 1:17 pm
That's great I didn't know. I didn't read this multiples of information before, good to know. It does indeed work.
Thank you andrew.
