(Solved) Paper Space Layers
seasdes
Senior Member
Post by seasdes » Mon Aug 08, 2022 12:58 am
What layer is recommended, for title blocks dimensions text etc, when drawing in Paper Space?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Re: Paper Space Layers
Post by Husky » Mon Aug 08, 2022 2:27 am
Hi seasdes,
I don't think there is for every case of application a pauschal working answer but I can tell you what works for me:
I have one Designated layer for that named "Drawing Sheet",
all blocks used for Frame, Title Block, Zoned Border etc are drawn on "Drawing Sheet". That allows me to turn EVERYTHING all together invisible in the Layer List or piece by piece in the Block List. Maybe this will work for you too ... :wink:
seasdes
Senior Member
Post by seasdes » Mon Aug 08, 2022 2:47 am
Thanks Husky.
So don't use any of the Model Space layers?
seasdes
QCAD Pro V3.27.8
User since 2021
W10
Post by CVH » Mon Aug 08, 2022 7:03 am
Just to be sure, Layers are not 'owned' by a Block like Model or Paper Space or any other Block.
seasdes
Senior Member
Post by seasdes » Mon Aug 08, 2022 7:26 am
Thanks CVH
seasdes
QCAD Pro V3.27.8
User since 2021
W10
