picking/selecting arc centre SOLVED
bambuko
Senior Member
Post by bambuko » Thu Dec 08, 2022 12:48 pm
I am having difficulty selecting the centre of (previously created) arc when creating new geometry.
I can dodge the problem - add arc radius and then select the end point of dim line, but otherwise it's no go... :oops:
It would be good to be able to select centre without having to use tricks :wink:
Any ideas please?
Version: 3.27.8.0 (3.27.8)
Internet: QCAD.org
Build Date: Oct 6 2022
Revision: dea3962
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
QCad Pro
Linux MX-21.3 "Wildflower"
Re: picking/selecting arc centre
Post by andrew » Thu Dec 08, 2022 1:14 pm
bambuko
Senior Member
Post by bambuko » Fri Dec 09, 2022 9:15 am
Simple, when you know how and where... :D :P
Thank you!
QCad Pro
