[Solved] Dimension mm - inch
Rantanplan7
Senior Member
Re: Dimension mm - inch
Post by Rantanplan7 » Thu Jul 23, 2020 12:19 pm
Still, my question is out.
Which question?
My problem was just that some library items had no unit and I changed / converted an existing drawing (in mm) into inches. After that step I added a library item (which was without a unit) and it was by far too large.
In the meantime I updated all items with mm unit and the problem is gone.
Best Regards
Sven
QCAD 3.27.6.0 / Windows 11 Professional 64-bit / 16 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Post by CVH » Thu Jul 23, 2020 1:31 pm
CVH wrote:
Thu Jul 23, 2020 10:44 am
The next question would be: why eg. M4x10_DIN84_f.dxf has no unit?
M4 & DIN84 >> mm ... Isn't it?
It works for Bath plan.dxf
That are very big screws compared with the bath.
Rantanplan7
Senior Member
Post by Rantanplan7 » Thu Jul 23, 2020 3:39 pm
I have no answer. It makes no sense to me.
Everything should have a unit unless it is something like a tree - so just something to enhance the beauty of a drawing.
In my drawing world everything has a clear dimension.
I make drawings to show the foot print of a cutting system.
And I have used CAD for planning furniture into a house or appartment and in all those cases I need correct dimensions.
Now in my case I assume the unit got lost while I was exporting symbols from Autosketch to QCAD.
Best Regards
Sven
