Hatch Properties
TheCabinetGuy
Hatch Properties
Post by TheCabinetGuy » Sat Jun 03, 2023 1:49 pm
Where do the default properties for hatching get set?
Re: Hatch Properties
Post by Husky » Sat Jun 03, 2023 6:07 pm
There are two hatch tools: Hatch from Selection (HA) and Hatch from Segments (HS). Properties are set in an up-pooping dialog.
https://www.qcad.org/doc/qcad/latest/re ... on_en.html
https://www.qcad.org/doc/qcad/latest/re ... ts_en.html
Post by CVH » Sat Jun 03, 2023 7:59 pm
Remark that there is only a default on first run.
The options in the hatch dialog are stored persistent between usage.
Both hatching methods share the same dialog.
The options are stored persitent in QCAD.ini/config.
Look for the header [HatchDialog]
For the properties of a hatch entity see Property Editor.
