Create text with opaque background
digidocs
Post by digidocs » Mon Jan 08, 2024 6:52 am
I'd like to add text to a drawing so that the text background is opaque. Something like the example below... Is this possible with QCAD?
Thank you!
Screenshot at 2024-01-07 23-50-44.png (15.62 KiB) Viewed 1513 times
Re: Create text with opaque background
Post by CVH » Mon Jan 08, 2024 8:25 am
Not right out the box. :(
One can add a solid filled hatch in the background color.
You need to set the text & border drawing order higher than the hatch drawing order and that higher than what must be blended out.
It can be problematic with 'Prevent white on white / black on black display'.
Disabling for printing or a slightly different hatch color might then be an option.
Remark that these are not associated entities.
One can group the hatch, the border and the text in a Block, re-inserted as a single Block-Reference.
digidocs
Post by digidocs » Mon Jan 08, 2024 5:28 pm
Thank you for the help!
I had hoped there would be an automatic way, but at least the capability is there. Have a good one.
