script question: keep selection + colored aux entity
Posted: Sat Dec 13, 2014 9:31 am
Hi there,
I'm working on scripts to support model railroad track planning. Creating tracks, moving and duplicate-moving are working now thanks to Andrew. Two things are missing and I don't have an idea how to implement them:
1. How do I keep a previous selection after execution of a copying Transform-operation? Use case: select track, dup+move several times. Currently the newly inserted objects are selected but I want to keep the originally selected objects selected.
2. I would like to draw a colored and filled auxiliary circle to mark the source track. I succeeded in creating a circle but not in an eye-catching color or with filled area.
Attached you'll find my current work-in-progress-snapshot containing an example file and the created scripts. These have to reside in ...qcad.../scripts/QCTrack. After insertion into the scripts-directory there will be a new main menu "QCTrack" with three items "Create", "Move" and "Duplicate and move".
Thank you for any comment, hint or help
Best regards
Stefan
Best regards
Stefan
