Bitmap Export default resolution
algrass
Post by algrass » Fri Sep 04, 2015 8:07 am
Is there a way to alter the default export resolution in the Export Bitmap dialog box? Current default is 640x480.Normally I export at 1920x1080 and would like to avoid changing this manually every time. Is there a .xml file I can modify to set my preferred resolution export?
Re: Bitmap Export default resolution
Post by andrew » Fri Sep 04, 2015 9:50 am
I've moved this to a feature request at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1259
A quick fix is available.
algrass
Post by algrass » Fri Sep 04, 2015 2:48 pm
Great Andrew. Thank you.
hungerburg
Post by hungerburg » Fri Sep 04, 2015 7:43 pm
Very nice, nicer still, if the dialogue would remember the file type too!
(I never save bmp but png most of the time…)
algrass
Post by algrass » Sun Sep 06, 2015 9:57 am
hungerburg wrote:Very nice, nicer still, if the dialogue would remember the file type too!
I agree entirely!
