Custom Line weight
ov10fac
Custom Line weight
Post by ov10fac » Sat Apr 30, 2016 8:27 pm
I need to set the line weight to 0.01MM, however there does not seem to be any way to do this. Can the line weight be set to something other than the ones that come with qcad. I need these small weights to generate laser cutting drawings.
Thanks.
Re: Custom Line weight
Post by Husky » Sat Apr 30, 2016 11:58 pm
ov10fac wrote:I need these small weights to generate laser cutting drawings.
Whats about 0.00? That should work as well.
ov10fac
Post by ov10fac » Sun May 01, 2016 2:17 am
I tired the 00 weight, but I need weight of .01 and that is not offered, nor is there any place to let me insert a valuel
Moderator
Post by Clive » Sun May 01, 2016 7:29 am
Hi is this for Epilog machines?
ov10fac
Post by ov10fac » Sun May 01, 2016 10:24 pm
Not sure what an Epilog machine is. I send the drawing to a company on-line from a company named Ponoko. They need all the laser cut lines set to .01 MM.
Thanks.
Post by andrew » Mon May 02, 2016 8:43 am
ov10fac wrote:They need all the laser cut lines set to .01 MM.
Do they accept a DXF / DWG file for processing? The problem is that lineweights of 0.01mm are not supported by the DXF/DWG format at all (which is the reason QCAD does not support such custom line weights either).
ov10fac
Post by ov10fac » Mon May 02, 2016 2:44 pm
Yes, they do support dxf format. i will check with the company to see what the dxf format rules are. Thank you
Post by Husky » Mon May 02, 2016 9:04 pm
ov10fac wrote:Yes, they do support dxf format. i will check with the company to see what the dxf format rules are. Thank you
I'm pretty confident they will accept 0.00 ... :wink:
Please check http://www.ponoko.com/starter-kits/autocad
@Andrew: Could you please whitelist this link - thanks.
ov10fac
Post by ov10fac » Mon May 02, 2016 10:57 pm
Ahh light bulb. I've been sending them inkscape drawings, which need line width of .01. I just assumed the same for dxf.
Guess I should have read all the documentation. Many thanks.
