Area inquire
olleb61
Area inquire
Post by olleb61 » Sat Sep 24, 2016 9:18 am
How do i set "info plygonal area" to show mesurements in square meters
Re: Area inquire
Post by Husky » Sat Sep 24, 2016 4:01 pm
Hi olleb61 - welcome to the forum,
olleb61 wrote:How do i set "info plygonal area" to show mesurements in square meters
This Info tool will always use the settings for "Drawing Unit" which can be found below "Menu / Edit / Drawing Preferences / General / Drawing Unit.
Be aware - just to change this setting in an existing drawing will not automatically change the scale of your drawing - you have to do that manually.
Hope that helps.
Moderator / Drawing Help
Re: Area inquire
Post by Clive » Sat Sep 24, 2016 7:57 pm
Hi olleb61
You could also select the text and use the property editor to change it to read something different, for example if your text reads 400 (and you are working in cm) you could change it to read 4M by using the property editor :wink:
