Help PDF
Re: Help PDF
Hello giosue - welcome to the forum!
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3317
Sounds like your drawing isn't correct positioned on the print paper. Here is a little tutorial which will help you to solve the problem.giosue wrote:Hi everybody.
Look,I got a problem I want to export to PDF,but when I do it (I click in File,but when I export it to PDF,the file is PDF file is empty) I dont know what can I do...
Re: Help PDF
Er...I also have a pdf problem (again!). I don't think it's the same, but I couldn't find the button to start a new thread. I have a rectified photograph, supplied by a surveyor as a dwg file, that I imported into qcad. I've added an archaeological overlay, as polylines, hatches, text etc, and need to print out sections with the lines and the photo. The print preview feature just does not seem to be working (although it worked on another file I tried) - all I can see is the little hand icon. I've checked and double checked the scales of everything (as I'm sure that's where the problem lies), uninstalled and reinstalled qcad, but it's still not working.
I'm getting a bit desperate here, so I hope you can help. (And on a minor note, I would like my white lines to print out as white, not black as they show in the preview - is that possible).
Very much looking forward to hearing from you.
Jackie
Jackie
Re: Help PDF
Please attach your drawing file, so we can help you efficiently. Read here how to attach files to your post.
Re: Help PDF and lost hatching
OK - I have three-quarters solved my own problem, but copying and pasting everything into a new drawing. Only problem is that all the hatching was lost in the transfer.
Any ideas?
Thanks, Jackie
Any ideas?
Thanks, Jackie
Re: Help PDF
Please understand that it is next to impossible to help without the file. Any ideas would just be shots in the dark...
Re: Help PDF
Sorry - our messages must have crossed in the ether. Thanks for your reply. Do you still need my drawing to solve the hatch problem?
Jackie
Jackie
Re: Help PDF
Files attached - thank you
- Wall17 W Elev Archaeology rev 1.dxf
- This is the file where I copied and pasted everything from the original file (and then made a few changes to). Print preview works, but hatch did not copy over
- (631.91 KiB) Downloaded 325 times
- This is the original file where the print preview did not work
- Wall17 W Elev Archaeology 3.jpg (73.88 KiB) Viewed 7748 times
Re: Help PDF
They look much better in qcad (and pdf)!
Re: Help PDF
Thanks. Is this the new file that works or the original file with the problems. I'd need the file with the problems, the one from where you copy the hatches. I have no problems copying the hatches from this file to a new drawing. I can only see one DXF and no DWG file attached to your post.
Re: Help PDF
Not sure which one you got. Wall17 W Elev Archaeology rev 1 is the one that works (that I copied everything into), so I've attached the original non-working one (that's Wall17 W Elev Archaeology 3)
- Wall17 W Elev Archaeology 3.dwg
- This is the one that doesn't work
- (131.31 KiB) Downloaded 335 times
Re: Help PDF
@Andrew
Vertex "Z" for a hatch looks crazy to me. Value is around 519669.710069 ... and after pasting I have problems to selected other than hatch entities too.
I can reproduce the problem with this drawing but honestly I don't know what causes the problem. Just for a temporary workaround copy as usual your drawing into a new one - you will not(!) see the hatch - then "Save as" with a new name - close it and reopen the file. Your hatch will then be displayed as expected.jackieh wrote:... so I've attached the original non-working one (that's Wall17 W Elev Archaeology 3)
@Andrew
Re: Help PDF
Hmmmmmmmmmmmmmmmmmm .... was that a test????
Ok, here an update:
I found an Image / Image Path in that drawing with a Position Value of Z=-1039339.420138
If I selected ALL and copy / past this selection into the same or in a new drawing QCad will be ..... confused.
Delete this image reference or set this Z value to 0 and everything works just fine ....
Ok, here an update:
Re: Help PDF
Thanks very much indeed for your help with this. I will try it out and get back to you if I have any other difficulties!
Jackie
Jackie
Re: Help PDF
OK, this time I copied (using a window to select what I wanted) and pasted, saved as, closed and opened, and everything seems fine (version attached for info). Better than the first time, which seemed to have lost the layer information (didn't notice that yesterday). I can't though, for some reason, highlight the image, so I can't see if it has a z value or not, or change it, although it is still in the image layer, so I can turn its visibility on and off. The hatches and other overlay info do not appear to have z values, hope you agree.
Has this solved the problem?
Jackie
Jackie
- ~Wall17 W Elev Archaeology rev 2.dxf
- New version - seems to work with exception of not being able to highlight image
- (629.29 KiB) Downloaded 339 times
