Is there in QCAD any possibility to transfer properties (similar in other programms with a brush-button),
for instance colour or kind of line,....
Thanks for any response.
Is it possible to transfer properties (lines,..)?
Re: Is it possible to transfer properties (lines,..)?
No, there's no way to copy attributes between entities.
Note that attributes are almost exclusively controlled by layers in CAD (color by layer, lineweight by layer, linetype by layer).
For more information about entity attributes and layers, please refer to:
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3202
If this does not answer your question, please elaborate on what you are trying to do, so we can help you most efficiently. Thanks.
Thanks, does not matter.
