Is there a way to set my Units to always use what I've set?
I want to work in MM but every time I create a new drawing, its in Inches.
[solved] How do I set MM Units as the default
Re: How do I set MM Units as the default
I found out how to set it.
For other users stumbling upon this, it's under
Edit > Application Preferences > Defaults for New Drawings > Drawing Unit
