QCAD manual
- Registered Member
QCAD manual
QCAD manual part 3 instruction 4. "Adjust the scale of the drawing area so that you can see a space of about 100 units horizontally. To do this keep an eye on the rulers that QCAD displays etc." How does one adjust the drawing scale to comply with the quoted instruction?
Re: QCAD manual
Hello john.shipton - welcome to the forum.
The term "Unit" is used because nobody can know what your unit is: mm?, inch?, meter?, yard?, Microinch? etc etc ....
Zoom your drawing in or out and keep an eye on the rulers. You can use the scroll wheel on your mouse or the +/- keys on your keyboard. It should look like this screenshot:john.shipton wrote:To do this keep an eye on the rulers that QCAD displays etc.
- Registered Member
Re: QCAD manual
Thank you Husky
