Multiple Text Entities
I wish to add text notes or item captions in various locations on a drawing. I can only seem to get the same text box every time and all text is positioned together.
Re: Multiple Text Entities
As always - there are multiple possibility's to accomplish a task like that one:
Maybe you like to try this one:
Launch the Text tool,
set to single line text, type your text, ok
place the text with a mouse click in your drawing,
change the Content in the Option box,
change the Content .................... and so on.
Thanks for the rapid response. I actually turned the 'single line' off because I was entering a multi line text block. Alan
Single line was just an example.AlanC wrote:Thanks for the rapid response. I actually turned the 'single line' off because I was entering a multi line text block. Alan
