Block Counter
Block Counter
Is it possible to count blocks as they are added to drawing and set up a table to show #?
- Untitled.png (18.42 KiB) Viewed 2539 times
Re: Block Counter
Yes and no ....FireAlarm wrote:Is it possible to count blocks as they are added to drawing and set up a table to show #?
There is a little script to count the used Blocks in your drawing and the result will be saved in a simple text file. But it isn't placed automatically in your drawing.
You can find the script below Menu / Misc / Block / Export Block List
