How to use the "relative zero set". Thank you
Relatif zero
Re: Relatif zero
In your drawing is an "Absolute zero point" which is fixed and noticeable as a red cross.Argos wrote:Hello,
The "Relative zero point" in QCad is noticeable as a small red circle with a cross which is movable (Set relative Zero) to any location in your drawing. You can use it as a temporary reference for a construction like: draw a new line from Relative Zero with a distance (Coordinate tool) of x5 y7.
BTW: All this and much much more information's are very good presented and explained in the QCAD Book. Maybe a good investment to learn general CAD concepts and QCAD itself:
http://www.ribbonsoft.com/shop/category ... ategory=77
Re: Relatif zero
Thanks for your explanation Husky
