I would like to know if it 's possible to set a printing color for a layer.
Example : a layer "shadow" is showed green on QCAD and is printed on grey
Thank's you,
Christian
setting printing color
Re: setting printing color
Unfortunately, this is currently not possible with QCAD.
I've added a feature request at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1552
- dfriasb
- Senior Member
I use to solve this with two "template" files. One with layers in "model" style an another with layers in "plot" style. Just import the proper file in your drawing "overlaying" layers.
