Font substitution option(-fs) on "dwg2pdf" not functional
ogata1
Post by ogata1 » Fri Mar 17, 2017 7:22 am
I am using qcad pro 3.16.5(linux-x86_32) and dwg2pdf to view and convert dwg files.
But there are one problem now.
Japanese text can not be shown correctly(???) when used Font substitution option(-fs).
Command is following:
./dwg2pdf -platform offscreen -fs Unicode Standard -block=\"*PAPER_SPACE\" -f -n -d -a -l -m 10 -o test.pdf test.dwg
dwg file is following:
https://drive.google.com/file/d/0B5wlDs ... sp=sharing
Could you please tell me why.
Thanks.
Re: Font substitution option(-fs) on "dwg2pdf" not functional
Post by andrew » Fri Mar 17, 2017 10:59 am
Thanks for your report. I've issued a bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1559
Note that you will likely want to substitute fonts Standard and RomanS with a true type font like "Arial" since even the CXF font "Unicode" only contains a subset of Japanese / Chinese glyphs.
Also the order of parameters would be:
-fs <font to substitute> <font to use instead>
For example:
./dwg2pdf -platform offscreen -fs romans Arial -fs standard Arial -block=\"*PAPER_SPACE\" -f -n -d -a -l -m 10 -o test.pdf test.dwg
