If a drawing is created using the 32bit version of QCAD or QCAD/CAM, can it then be loaded using the 64bit version of QCAD or QCAD/CAM? Can drawings made under one operating system (Windows, macOS, Linux) be loaded on another operating system?
Drawing created with 32bit / 64bit software
From a QCAD user:
Re: Drawing created with 32bit / 64bit software
Yes. Drawing files are completely independent of the platform that was used to produce them. A DXF/DWG file created with QCAD on any platform (be it Windows, macOS or Linux / 32bit or 64bit) can be loaded on any other platform.
