outer angular dimension
Is it possible to get a dimension over the largest angle between two lines?
15.6 GiB memory - i7-9750H CPU @ 2.60GHz - GeForce GTX 1650 - Latest Ubuntu
Re: outer angular dimension
Something like this?
This is done with Dimension / Aligned and Dimension / Angular
I mean the other side of that angle: 328.69˙
To my knowledge that is currently not an option. But maybe you like to fill a Feature Request below:
http://www.ribbonsoft.com/bugtracker
I found out that when using Inquiry Angle I can get both angles and there is an option to add measurement to drawing.
