Sorry for the repost, folks, but I figured this might be a more appropriate forum. I'm a first timer and I'm going through the book and here it says "Adjust the scale of the drawing area so that you can see a space of about 100 units"
How would I go about doing this?
I'm using the latest QCAD Pro, Windows 10 and I'm working in inches. Here's a screenshot.
"Check the bottom right corner of the drawing area to make sure that the grid is currently shown with a spacing of 10 units ( the text 10/100 is shown)"
Is the red circle what they're talking about?
I imagine it's right in front of me, but I'm not getting it. Could someone please break this down for me and make sense of it?
Any help would be greatly appreciated, thank you very much.
Adjust scale of drawing area...
Re: Adjust scale of drawing area...
Perfect - thanks for helping us to keep the forum clean.ZellisE82 wrote:Sorry for the repost, folks, but I figured this might be a more appropriate forum.
With the scale of the drawing is meant the zoom factor of the drawing. You can zoom in and your actual drawing appears "bigger. You can zoom out and the drawing appears "smaller". But that is only a "View" like a used magnifier. It will not change anything in your drawing.ZellisE82 wrote:"Adjust the scale of the drawing area so that you can see a space of about 100 units"
With zooming in or out your rulers will adjust the shown units / divider regarding to the zoom factor. Just zoom your drawing until you have this 100 units shown what they are asking for.
How to zoom? They are many different ways in QCAD to do that - the result is always the same. Use your Keyboard and play around with the plus (+) or minus (-) keys. Or just - if you have - scroll the mouse wheel up or down. You get the point.
Yes. 10/100 reflects your settings for Grid Spacing (10) and Meta Grid Spacing (100)ZellisE82 wrote:"Check the bottom right corner of the drawing area to make sure that the grid is currently shown with a spacing of 10 units ( the text 10/100 is shown)"
