[solved] Anchored Boat
djwright
Post by djwright » Tue Aug 15, 2017 11:16 am
Imagine a rectangular boat.
It is anchored to fixed points on the seabed with a line from each corner of the rectangle.
I would like to be able to move the rectangle around with lines connected to the fixed points
So if I move it to the right the 2 lines on the left get longer and the 2 lines on the right get shorter.
Is it posible to do this with QCAD?
Anchored Boat Problem.jpg (131.11 KiB) Viewed 2253 times
Re: Anchored Boat
Post by andrew » Tue Aug 15, 2017 11:24 am
Yes, you can use Modify > Stretch for this.
- Modify > Stretch
- "Draw" rectangular area around your rectangle
- Click a reference point (any point)
- Click the target point
djwright
Re: Anchored Boat
Post by djwright » Tue Aug 15, 2017 3:11 pm
Thanks. That is exactly what I was looking for. Dave
