Leader with diameter
I want to show a circle's diameter externally on the circumference of the circle with a leader. I created the below with a leader and text block, I entered the value manually. How do I achieve this so that the displayed text value is the actual diameter?
Qcad 3.17.3 Rev: 9c7770f on Win7ProRe: Leader with diameter
In the current QCAD Version exist no automatic Value reading to feed a Leader Text. If the common Dimension tools are not suitable to your needs and you need for some reason the Leader tool on a regularly base then I would recommend to create Leader Blocks with an Attribute function. That still means you have to put in manually the Value but it makes your Life easier ...frankg wrote:I entered the value manually. How do I achieve this so that the displayed text value is the actual diameter?
I covered four possible positions what means I created 4 Blocks ...
... but honestly I use it only if I see no other way and that is not very often.
Thanks Husky - I will do as you suggest until such a feature is available
