center of gravity
greed
center of gravity
Post by greed » Tue Oct 03, 2017 5:38 pm
How can I find the geometric center of a polygon ?
How would I find the center of gravity or geometric center of two separated polygons ?
I'm trying to find the CLR (center of lateral resistance and the CE (center of effort ) on a sailboat plan.
Re: center of gravity
Post by andrew » Tue Oct 03, 2017 5:43 pm
I'm afraid QCAD does not include tools to compute any of these specific points.
Post by CVH » Sat Jun 02, 2018 4:18 pm
https://en.wikipedia.org/wiki/Centroid
Sroll down to
Centroid of a polygon
Post by CVH » Wed Oct 20, 2021 8:20 am
Andrew,
Stumbled on:
InfoPolylineArea.prototype.getCenter()
InfoArea.prototype.getCenter()
As far as I can tell that is the centroid of a non-self-intersecting closed polygon defined by n vertices.
Added to QCAD on May 11, 2016 :!:
But here only valid for polygons with CW orientation.
There the getArea() returns an absolute value and the polygon is assumed to be CCW.
Seems contradictory ...
The source in the wiki defines the area of a polygon as:
http://paulbourke.net/geometry/polygonmesh/
-> "Calculating the area and centroid of a polygon"
And that seems to not match with:
    var j = nPts - 1;
    for (var i = 0; i < nPts; j = i++) {
        p1 = pts[i];
        p2 = pts[j];
        area += p1.x * p2.y;
        area -= p1.y * p2.x;
    area /= 2;
There p2 is the previous point and not the next point aka (xi+1, yi+1)
Same goes for the centroid formula and the js code of both the getCenter() mentioned above:
Bottom line:
When I swap p1 and p2 and allow for negative values for the area then all turns to be OK.
Further simplified there both getCenter & getArea iterate the same point cloud and value f can be summed to the signed area:
InfoArea.prototype.getCenter = function() {
    var pts = this.polyline.getVertices();
    var nPts = pts.length;
    var x = 0;
    var y = 0;
    var f;
    var j = nPts - 1;
    var p1;
    var p2;
    var area = 0;
        p2 = pts[i];
        p1 = pts[j];
        f = p1.x * p2.y - p2.x * p1.y;
        x += (p1.x + p2.x) * f;
        y += (p1.y + p2.y) * f;
        area += f;
    f = area * 3;
    return new RVector(x / f, y / f);
Post by andrew » Wed Oct 20, 2021 10:02 am
Thanks, looks indeed like a bit of orphaned code. I've removed it.
Post by CVH » Wed Oct 20, 2021 10:56 am
My intention was to correct it and include it as the centroid position of a polygon ...
Pitty...
Post by andrew » Wed Oct 20, 2021 11:17 am
Yes, I might get back to this if time allows...
guyrinf
Post by guyrinf » Wed Oct 20, 2021 11:33 am
operating system: Ubuntu 18.04
Qcad 3.26.4.9
Too bad, I have to use Turbocad to find the center of gravity. It would be so good to include it in Qcad. I often work with sailboat plans on Qcad.
Post by CVH » Fri Oct 29, 2021 12:01 pm
guy,
Please refer to:
viewtopic.php?t=8846
