[solved] Arcs
slyde
[solved] Arcs
Post by slyde » Tue Dec 12, 2017 1:54 am
Hi Forum:
This isn't a QCAD-specific issue, just something I need help with. I don't understand how to draw this:
EXERCISE 3.jpg (84.33 KiB) Viewed 3383 times
That's a drawing another user here put out for me to try to draw. And this is what I ended up with:
Screenshot from 2017-12-11 18-44-52.png (10.56 KiB) Viewed 3383 times
My arcs are way off. The only one I think I got right was the middle one (R35). I'm pretty good with math, but I can't figure this one out. The one day I skip school and I missed this lesson :D Will someone please point me in the right direction? Thanks.
Slyde
ex-3.dxf
(136.49 KiB) Downloaded 327 times
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: Arcs
Post by Husky » Tue Dec 12, 2017 3:07 am
With this given information I would use the Round (RN) tool ....
Center radius = 35
inside / outside measurements are known ø26/ø40
So, launch the Round Tool, the outside radius (1) for the pipe needs to be 35+20 (put this mathematical expression directly in the Radius field .... or search for your Pocket-calculator .... :wink: )
use then horizontal / vertical entities to built the round ...
slyde
Re: Arcs
Post by slyde » Tue Dec 12, 2017 3:35 am
Thanks, Husky. Like you said to me, I drew out my vertical and horizontal lines of the pipe's OD and ID, then used the Round tool. But I didn't know how to formulate the curves (arcs). But I now see what you're talking about.
35+20
35+13
35-13
35-20
Screenshot from 2017-12-11 21-49-48.png (10.69 KiB) Viewed 3371 times
Sure do appreciate you.
Re: [solved] Arcs
Post by Husky » Tue Dec 12, 2017 4:35 am
Looks good! :wink:
