Maybe it's possible or not...
Is it possible to generate a shape based on two other shapes?
E.g. if It would have a 100x100 square and a 50x80 rectangle would it be possible to generate a 75x90 rectangle automatically (supposed that they interpolation would be in 50pct of the range).
Offset don't do the trick I guess.
Interpolate between two shapes
- Registered Member
- IMG_20171212_150125.jpg (2.08 MiB) Viewed 1987 times
Re: Interpolate between two shapes
Hi Dries_neyrinck - welcome to the QCAD Forum.
No.Dries_neyrinck wrote:Is it possible to generate a shape based on two other shapes?
