[solved] Printing Page / wrong unit used
Post by Husky » Tue Dec 19, 2017 7:19 am
this is hunting me for a while and maybe somebody knows how to fix that.
Case:
General Drawing Units all imperial/inch,
Mode_Space / Printing Page is using inch = perfect,
Paper_Space / Printing Page is using mm. WHY? Ok, the conversion is correct but I need to see that in inch.
And now the info what every Programmer is looking for: It is not stable in Paper_Space! It will change the unit on itself from mm to inch or back, always with the same Paper Size, correct value in mm or inch and ......................... I can't reproduce it! I can trigger that with switching back and forth between Model_Space and Paper_Space but I can't see a pattern.
Any Ideas? :shock:
settings mm inst inch.dxf
(106.53 KiB) Downloaded 197 times
Re: Printing Page / wrong unit used
Post by andrew » Wed Dec 20, 2017 4:52 pm
Can you check if that problem is fixed in 3.19.2, thanks.
Post by Husky » Fri Dec 22, 2017 7:09 am
andrew wrote:Can you check if that problem is fixed in 3.19.2, thanks.
Hmmm - til now it looks good! I tried hard but wasn't able to trigger it again. I'll keep an eye on it but I have a good feeling .... :D
Thank you very much for looking into this!
