[solved] Offset path is incomplete
yetanotheruser
Post by yetanotheruser » Sun Dec 31, 2017 4:03 pm
Hi all,
I am using the Modify - Offset (with Distance) function to outset this polygon by 10 mm:
However, the result is not as expected - note the gap in the lower right corner:
Can anyone tell me, what causes this gap? To my best knowledge the original polygon consists of one continuous line - when hovering over it, one can see, that the complete polygon is selected. Therefore I don't understand what causes this strange result. For me it looks like the original polygon is somehow discontinuous, but I can't see how this should be the case.
The dfx file (with only the original polygon) is attached.
Operating system: Windows 10 x64
QCAD version: Qcad Pro 3.19.2
Thanks for any hint on this!
back.dxf
(195.55 KiB) Downloaded 25 times
Last edited by yetanotheruser on Tue Jan 02, 2018 2:24 pm, edited 1 time in total.
Re: Offset path is incomplete
Post by Husky » Sun Dec 31, 2017 8:49 pm
Did you uncheck "Clipping" in the option bar?
yetanotheruser
Post by yetanotheruser » Mon Jan 01, 2018 4:32 pm
Thanks, that was it - after unchecking this option everything worked as expected :D
Can you tell me when this option is useful and when not? What's the intention behind this function?
The clipping option is actually not mentioned in the Offset documentation ):
https://qcad.org/doc/qcad/latest/refere ... ro_en.html
Post by andrew » Tue Jan 02, 2018 1:24 pm
Gaps are usually caused by tolerance issues. These tend to occur if a polyline contains arc segments with very large radii as is here the case.
A potential solution (other than turning off clipping) might be to straighten all arc segments into line segments using Draw > Polyline > Arc to Line Segments.
yetanotheruser
Post by yetanotheruser » Tue Jan 02, 2018 2:23 pm
andrew wrote:Gaps are usually caused by tolerance issues. These tend to occur if a polyline contains arc segments with very large radii as is here the case.
Thanks for the explanation and alternative workaround :D
