Text escape sequences not working - What am I missing?
lphilpot
Post by lphilpot » Mon Jan 01, 2018 4:18 am
QCAD Pro 3.19.2 on Linux
I'm reading / working through the QCAD book and tried some text sequences. When I insert them with the property editor or dimension dialog fields, they work. However, if I try to put them in a text block or add them to a dimension after the fact, they're treated literally. For example:
I thought I might have the syntax wrong, so I copied the examples on the left from the QCAD PDF (pasted into a text editor first, then recopied to verify no hidden characters were captured). The dimensions on the right were done in property editor fields and they work, but based on a previous attempt if I were to remove the tolerances and enter them as S\<superscript\<subscript>;, they'll show up literally as on the left.
I created the text entities and pasted the escape sequences directly into the source window of the text editor:
So what am I missing or doing worng? :wink:
Thanks.
QCAD_text_escapes.dwg
(18.59 KiB) Downloaded 37 times
Len
QCAD Pro on Xubuntu Linux (usually)
Re: Text escape sequences not working - What am I missing?
Post by andrew » Fri Jan 05, 2018 12:10 am
This has indeed changed at one point (for compatibility reasons). The sequences should be:
100m\S2^;
X\S^1;
10\S+0.10^-0.25;
Σ\S6^k=2;(k\S2^;)
I've also adjusted this in the book for the next release of the e-book / printed book. Thanks.
lphilpot
Post by lphilpot » Fri Jan 05, 2018 2:27 am
Ah, makes sense. Thanks!
Len
