[solved] How to delete a polyline segment between two nodes?
yetanotheruser
Post by yetanotheruser » Mon Jan 01, 2018 6:53 pm
I need to delete a polyline segment between two polyline nodes. I tried with the Delete Segments between Two Nodes tool, but this actually deletes the line and then immediately creates a new one. Quote from the documentation:
After the segments are deleted, the two limiting nodes are connected by a straight line segment so the polyline is still one continuous sequence of line segments.
In my case the two limiting nodes are actually directly the nodes between which I want to remove a segment. So, how can I remove a polyline segment between two polyline nodes?
Here's a screenshot for better illustration, I also attached the drawing.
Thanks for any hint on this :)
Operating system: Windows 10 x64
QCAD version: Qcad Pro 3.19.2
back_test.dxf
(153.07 KiB) Downloaded 11 times
Last edited by yetanotheruser on Mon Jan 01, 2018 8:06 pm, edited 1 time in total.
Re: How to delete a polyline segment between two nodes?
Post by Husky » Mon Jan 01, 2018 7:29 pm
yetanotheruser wrote:I tried with the Delete Segments between Two Nodes tool, but this actually deletes the line and then immediately creates a new one.
This tool isn't suitable for that task. It will remove a segment but keeps the polyline intact.
You are looking to delete the segment. Just explode the polyline and then select and delete the particular segment.
yetanotheruser
Post by yetanotheruser » Mon Jan 01, 2018 8:06 pm
Thank you, that did the trick :D
I was used to another meaning of "Delete Segments between two nodes" from another software.
Post by Husky » Mon Jan 01, 2018 8:27 pm
yetanotheruser wrote:Thank you, that did the trick :D
You're welcome.
yetanotheruser wrote:I was used to another meaning of "Delete Segments between two nodes" from another software.
There is "other" software out there??? e_confused e_surprised :lol:
