Sizing drawings
Don W
Sizing drawings
Post by Don W » Fri Jan 05, 2018 8:03 pm
I am sure I am missing something basic but I have multiple drawings that when I try and open each in a new drawing the scale is VERY different. the one thing I notice is the "Meta grid" data at the bottom is different for each file. in one case 10" <8'-4" the other is 0.1< 1
Almost all of my drawings can be full size. that is 1 to 1.
How do I set this as my "standard"?
How do I change exiting drawings to the that standard?
Don
64 bit operating system ( Windows 7 Pro)
Q CAD Pro 3.17.3.0
Front cover.dxf
(3.03 MiB) Downloaded 322 times
front cover dimensions.dxf
(119.93 KiB) Downloaded 312 times
OS is Win7 Pro
QCAD Pro is Version 3.17.3.0 (3.17.3)
Revision 9c7770r
Re: Sizing drawings
Post by Husky » Fri Jan 05, 2018 9:15 pm
Hi Don,
Don W wrote:I am sure I am missing something basic but I have multiple drawings that when I try and open each in a new drawing the scale is VERY different.
That is an "opening" Zoomfactor. In your case it is set to "Auto zoom on load" what means it shows everything in your drawing at the first load. To deactivate this option go to Application Preferences ...
After changing this setting the current Zoom factor during saving the drawing will be used.
Don W wrote:... the one thing I notice is the "Meta grid" data at the bottom is different for each file. in one case 10" <8'-4" the other is 0.1< 1
This display response to your Dimension settings. Same settings in different drawings leads to the same display.
Don W wrote:How do I set this as my "standard"?
Application Preferences are responsible for NEW drawing. Existing drawings have to be changed manually below Drawing Preferences.
Don W
Re: Sizing drawings
Post by Don W » Sun Jan 14, 2018 11:11 pm
THANK YOU!!! That solved the problem.
Is this typical of CAD programs or something unique to Q CAD? I come from a graphics background ( Corel) and this is a different approach
OS is Win7 Pro
Revision 9c7770r
Re: Sizing drawings
Post by Husky » Mon Jan 15, 2018 1:01 am
Don W wrote:THANK YOU!!! That solved the problem.
You're welcome.
Don W wrote:Is this typical of CAD programs or something unique to Q CAD?
Typical for CAD programs.
