Hello all,
Where can I find the syntax for filtering using Selection Filter widget with Regular Expressions?
I'm trying expressions like "2+1", "=2+1", etc. but they are not working...
Thanks!!
David
Filter with Regular Expression
- dfriasb
- Senior Member
- Screenshot from 2018-01-07 10-56-02.png (325.45 KiB) Viewed 3447 times
Re: Filter with Regular Expression
Regular expressions can be used to define a search pattern. Regular expressions can be very complex, but there are also some simple but useful ones:
"ABC.*" matches layers starting with "ABC"
".*ABC" matches layers ending with "ABC"
".*ABC.*" matches layers containing "ABC"
"[1-4]" matches numbers 1 to 4
"\d" matches a digit
More information:
https://regexone.com/
http://www.rexegg.com/regex-quickstart.html
and others...
This examples would match everything on layers "layer 2" and "layer 3":
More information:
and others...
- dfriasb
- Senior Member
Very interesting!
Thank you!!
Thank you!!
