I am quit new QCAD and would like to find a simple, free and easy to use solution to view QCAD files.
Who knows about a viewer app for macOS, Windows and Linux (or even iOS and Android) that could open and view QCAD produced files (.dwg or .dxf)?
Of course I could use the free versio of QCAD or another free CAD program that can handle dog or dxf files. But I am searching for a more simple and easy to use viewer for customers, or installation or support teams who need to view installation documents on site.
For example Autodesk offers a web-base viewer for free that works with QCAD files, but the process is too complicated and slow. You have to be online and then sign in to you created account and upload the file before you are able to see it in your browser.
Thanks for your thoughts on this!
Andreas
p.s. Of course you could always export files to PDF. That is also my current workflow...
QCAD viewer
- Senior Member
Re: QCAD viewer
Although this is already a couple of weeks old. The free picture viewer irfanview can do this (dwg and dxf files) with the plugin BabaCAD4Image.
Best Regards
Sven
QCAD 3.27.6.0 / Windows 11 Professional 64-bit / 16 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Sven
Re: QCAD viewer
Thanks for the hint! I understood that this software only work on Windows.Rantanplan7 wrote:Although this is already a couple of weeks old. The free picture viewer irfanview can do this (dwg and dxf files) with the plugin BabaCAD4Image.
Re: QCAD viewer
Hi Andreas,
There is also a 'Teigha File Converter' which allows you to convert any DWG to DXF. Also convert any DXF to DWG. This also works on the same operating systems as the viewer.
Hope this helps.
Regards
riverbuoy
You want a viewer called 'Teigha' produced by the 'Open Drawing Alliance'. Google 'Teigha Fie Viewer'. The page only mentions DWG and DGN files, but it also displays DXF files. There are versions available for Linux, Windows, Mac OS and Android.Andreas_FI wrote:Who knows about a viewer app for macOS, Windows and Linux (or even iOS and Android) that could open and view QCAD produced files (.dwg or .dxf)?
Hope this helps.
Regards
riverbuoy
Re: QCAD viewer
Wow! This is even better! Thanks riverbuoy.riverbuoy wrote:Hi Andreas,
Hope this helps.
Regards
riverbuoy
