Hiding blocks using layers
Post by andrew » Thu Feb 22, 2018 11:58 am
From a QCAD user:
How to make a block for insertion on certain layer, so that the block is only visible if that layer is visible.
Re: Hiding blocks using layers
Each block reference ("block insertion") is placed on a layer. If that layer is switched off, the block reference is also turned off.
1. Insert block "block1" on layer "A".
2. Insert block "block1" on layer "B".
Turning off layer "A" will hide the instance of "block1" on layer "A".
Turning off layer "B" will hide the instance of "block1" on layer "B".
