Stretch button
Flynny
Stretch button
Post by Flynny » Sat Feb 24, 2018 4:13 pm
I have downloaded the architecture add-on into QDAD PRO V3 and I am trying to stretch the window. I have followed the instructions in the manual and it just wont stretch. There is no error message on the command line.
Can any one help?
kind regards
Tony
PLAN2.dxf
(142.26 KiB) Downloaded 126 times
Re: Stretch button
Post by Clive » Sat Feb 24, 2018 4:32 pm
Hello Flynny,
The stretch command will work with contours.
You will need to make the elements which make up the window rectangle a continuous polyline first.
1.Use the divide tool to define the two short ends first:
stretch 1.jpg (32.55 KiB) Viewed 1720 times
2.Now select all four sides of the rectangle which make up the window symbol and use the create a polyline from segments tool:
stretch 2.jpg (37.07 KiB) Viewed 1720 times
Now run the stretch tool again.
stretch tool.jpg (21.78 KiB) Viewed 1723 times
Re: Stretch button
Post by Husky » Sat Feb 24, 2018 5:56 pm
Hello Tony - welcome to the forum.
Flynny wrote:I have followed the instructions in the manual and it just wont stretch.
The Stretch tool doesn't works on inserted Blocks. You need to explode the Block in your drawing. If all windows have the same size then maybe it makes more sense to change the Block itself (Block List / Edit contents of selected Block).
Flynny
Re: Stretch button
Post by Flynny » Sun Feb 25, 2018 11:34 am
Thank you very much for taking the time to help me
The quality of your response is outstanding
Kind regards
Flynny
Re: Stretch button
Post by Flynny » Sun Feb 25, 2018 11:36 am
I will be utilising both methods in the future
Kind regards
Flynny
