Merging dxf files with unknown height under each other
btjacker
Post by btjacker » Wed Mar 21, 2018 8:56 am
Hi, I am working on a python app for creating control unit documentation. I have a plenty of dxf files (schemes with same width but different heights) and based on conditions I select some of them, modify it with ezdxf package (translate text, change blocks attributes) and then I need to merge them together (under each other). I could manually add a top and bottom point to each scheme and calculate the distance between them but i wouldnt like to do it this way. Is there any other way how to get height of each dxf drawing or do something like code before
<merge xmlns="http://qcad.org/merge/elements/1.0/" unit="Millimeter">
  <item src="1.dxf">
     <insert x="0" y="0" />
  </item>
  <item src="2.dxf">
     <insert x="0" y="sum_of_heights_all_items_before" />
  </item>
  <item src="3.dxf">
  </item>
</merge>
Re: Merging dxf files with unknown height under each other
Post by andrew » Wed Mar 21, 2018 10:26 am
You can use the bbox command line tool to determine the minimum / maximum extents and size of a drawing:
bbox drawing.dxf
Min: -37/-104
Max: 112.4/24
btjacker
Post by btjacker » Wed Mar 21, 2018 10:40 am
I have not known about this tool, thank you andrew.
