angular dimensioning greater than 180°
Always indicate operating system, QCAD version
Attach drawing files, screenshots
Post one question per topic
Re: angular dimensioning greater than 180°
Post by andrew » Wed May 02, 2018 10:34 pm
J-J wrote:if I select the handle of a dimension, I cannot manipulate it anymore
Thanks. That's been fixed for the next release.
J-J wrote:and there are two additional circles that do not seem to do anything either. Anyone noticed that?
You can click them to swap the arrows (inside/outside). This is an experimental feature of the snapshot release.
J-J
Moderator
Post by J-J » Thu May 03, 2018 7:02 am
Thanks Andrew,
After posting, I looked at the property editor and found that feature, that worked within the editor but not with the mouse either :D
JJ Win7 pro-64
Post by andrew » Thu May 03, 2018 9:16 am
J-J wrote:but not with the mouse either :D
I cannot reproduce this here. Be sure to click the reference points (not drag them). If you cannot get it to work: what platform are you on?
J-J
Moderator
Post by J-J » Thu May 03, 2018 9:39 am
Got it, it works.
I first tried to play with those circles like the the square handle! (I'm on Win7-64)
JJ Win7 pro-64
Post by Husky » Thu May 03, 2018 6:28 pm
I run in the same problem like J-J but now I understood how it works. I'm on Win10/64.
Question: If I tricker the flip with the mouse it flips both arrows. Single arrow flip with the mouse isn't possible, correct?
Post by andrew » Thu May 03, 2018 6:33 pm
Husky wrote:Single arrow flip with the mouse isn't possible, correct?
Correct. Both arrows pointing the same way is almost never desirable but can be done using the property editor.
J-J
Moderator
Post by J-J » Fri May 04, 2018 3:56 pm
I really like that flip feature for the dimensioning arrows, great :D
JJ Win7 pro-64
