Hello, recently i created a variable 'x' that changes whenever i run the script. Now i want it to be displayed on my .ui widget i created in qt. I know how to call an input text box value from qt to qcad script but i couldn't manage to change this value and display it on my widget.
In other words, briefly i want qt lcd display number changes with respect to script variable whenever i run the code
Is there a sample script for that? or a function?
Thanks.
Put a variable on qt's display widget
Re: Put a variable on qt's display widget
QLCDNumber has a property called digitCount:
http://doc.qt.io/qt-5/qlcdnumber.html#digitCount-prop
So if w if your LCD widget, you can simply do:
w.digitCounter = x;
w.digitCounter = x;
