Select multiple
wendi
Select multiple
Post by wendi » Mon May 21, 2018 12:32 am
Hi. Is there are way to select more than one object at a time for editing? Typically one can "control-click", but that doesn't seem to work in Qcad. For example, I want to edit the color of a dozen texts. I can do each one individually, but it would be nice to select the ones I want to change, and then do them all in one action. Thanks.
Re: Select multiple
Post by Husky » Mon May 21, 2018 3:49 am
Hi - welcome to the forum.
wendi wrote:Typically one can "control-click", but that doesn't seem to work in Qcad.
it works with shift-click. :wink:
BTW - below Menu / Select are a bunch more possibility's.
wendi
Re: Select multiple
Post by wendi » Mon May 21, 2018 4:10 am
Thank you! Not at all obvious or intuitive!
Panchdara
Re: Select multiple
Post by Panchdara » Mon May 21, 2018 9:00 pm
wendi wrote:Thank you! Not at all obvious or intuitive!
Actually it is intuitively obvious as so many other other apps use this convention.
Windows 10
