Using blocks among multiple drawings
Win10, QCad 3.20.1 Hello. I've created my first drawing, and during the process, created about twenty blocks. I would like to use those same blocks in a new drawing. Is that possible? Thank you.
Re: Using blocks among multiple drawings
Yes - that's possible. You can do that with help of the clipboard ....
https://www.qcad.org/rsforum/viewtopic.php?f=47&t=5474
... or you can create your own Library Items to use those blocks more convenient in all your drawings
https://www.qcad.org/rsforum/viewtopic.php?f=47&t=2581
