How do you extrude in Qcad ?
I have a 2d design (lines in xy, that I want to extrude to 3mm thickness)
Guess I have to make the surface solid (face as in solidworks,autocad,freecad etc) before I can extrude, but the manual is vague if this is possible.
It sure is as I saw in youtube videos, but the manual is really difficult to search for terms.
Extruding a 2-dim object
- Full Member
Re: Extruding a 2-dim object
QCAD is strictly 2D. You can create an isometric projection, but there is no concept of solid 3D bodies in QCAD.
- Full Member
So why do you have a Chamfer option then? See Modify => Chamfer
How do you chamfer an edge if it has no thickness ?
It stumps me how I can chamfer a design with zero thickness.
Please refer to the user manual to learn what Chamfer / Bevel does in 2D:
http://qcad.org/doc/qcad/latest/referen ... /doc/Bevel
- Full Member
Ok, so I completely misunderstood what Qcad can do.
Well then its not going to be able to CNC any 2dim objects of uniform thickness, with chamfers in the z-direction.
Unfortunately not what I have been looking for as that is crucial for 2d objects.
Thanks for the help.
Sure.. good luck!
