union or clip polylines
bernieke
Post by bernieke » Fri Jun 15, 2018 9:40 am
What I'm trying to accomplish is prepare some text for vector laser engraving.
I start of by exploding my text into polylines, which gives me a single polyline per letter (or two, in case of an e or o, ...)
But this font has some overlap in the letters.
So I'm looking for a way to get rid of this overlap by joining the overlapping lines into a single line.
I can do this by creating a polyline offset, which gives me two separate polylines, one for the part I want to keep, and one for the overlap, which I can then remove.
But this is a lot of manual work (and adds a little offset I don't really need), so I'm looking for an easier way to accomplish this.
This is what I'm starting with:
This is what I should end up with:
qcad 3.20.1-pro on x64 linux
polyline_union.dxf
(118.03 KiB) Downloaded 224 times
Re: union or clip polylines
Post by Husky » Fri Jun 15, 2018 5:04 pm
Hello bernieke - welcome to the QCAD Forum.
Could you please attache the dxf or dwg for this example. Thanks.
bernieke
Post by bernieke » Fri Jun 15, 2018 5:16 pm
I've edited my original message and attached an example file. It has the text in font Motion Picture as well as the exploded text (polylines) and the by me manually changed version using the offset trick.
Post by Husky » Fri Jun 15, 2018 5:38 pm
Thanks.
Have you tried to use the "Break out Segment" tool?
If your CAM requires an overall joined Polyline you can do that then with "Create from Segments".
bernieke
Post by bernieke » Fri Jun 15, 2018 5:45 pm
That certainly works much better than the offset method.
But it's still a very manual process. Ideally I should just need to select all the text and have it do its thing in a single operation. (Like the explode does.)
But it's certainly a big improvement already, thanks!
