?Numbers lower right corner
Don W
Post by Don W » Sun Jun 17, 2018 5:54 pm
in the lower right corner of the drawing there is a group of numbers. How does one change them? They are obviously some sort of scale but every one of my drawings has a different set of numbers! they range from 10<100 to 8'4"<83'4".
When I open a drawing and try to bring in another they are different scales. This in spite of the fact that all of my drawings are done full size.
I am sure this is an "operator input error" but I am stumped by why or how to change it.
Attached DXF file has 3 drawings 2 are squared the third is stand alone.
OS is Win7 Pro
QCAD Pro is Version 3.17.3.0 (3.17.3)
Revision 9c7770r
Re: ?Numbers lower right corner
Post by Husky » Sun Jun 17, 2018 7:04 pm
Those numbers indicate the Grid spacing. They can change with a different zoom factor - depends on your settings.
