Template path to a Drive Name
Post by Husky » Tue Aug 07, 2018 3:53 am
I need to use QCAD Pro on a USB Drive. I like to use also Templates which has to be used only within that USB Drive. I was able to tell QCAD where to find and save the qcad3.ini on the USB regardless a changing Drive letter with using a Drive Name.
Now I need to use a Drive Name for a Templates folder too. Is that possible? If yes - how? :oops:
