how to select a single entity?
whistler1
Post by whistler1 » Sun Aug 26, 2018 8:22 am
I'm puzzled; I'm using version 3.21.2; I can't find a tool to click select a single entity.
This page http://www.mlb.co.jp/linux/science/qcad/doc/en/012.html
shows such a tool in the selection tools; however my qcad does not show the "single entity" tool.
I can often work around it by using rectangle selection; and sometimes - apparently at random - I CAN click-select. Please help?
select tools.png (7.42 KiB) Viewed 3446 times
Re: how to select a single entity?
Post by Husky » Sun Aug 26, 2018 6:25 pm
You are using a publication which is at least 17 years old. I can't recommend such aged documentation because many things are changed over the years ...
Asuming you are on Windows (?),
You don't need to launch a specific tool for a single selection. Just use your Mouse pointer left Button to select an entity. To select or deselect multiple single entities use the combination Shift + Left Mouse click.
whistler1
Post by whistler1 » Thu Aug 30, 2018 6:42 am
Thanks Husky;
I select a shape tool and draw a rectangle.
I go back (esc or back arrow tool) to the tool chooser and pick "select"
the top left shows the "active tool" as draw a rectangle. When I left-click it draws another rectangle.
Clicking on the "active tool" shows no options.
In thrashing around I think I've found my answer.
If I click ABOVE the "active tool", repeatedly RIGHT click or repeatedly press escape the "active tool" gets unset.
It would be more helpful (and intuitive) if the select menu included an "entity select".
Hopefully my struggles will benefit someone else at some time.
Thanks again
Post by Husky » Thu Aug 30, 2018 7:11 am
You don't have to pick a selection tool for that matter! The single entity selection with your left mouse button is always available when no other tool is active.
My previous answer explains why it is not included in the Selection Menu. :wink:
